Albe to bulk mute Triggers? (e.g. during 13 colonies)
During the recent 13 colonies event, I wanted to MUTE all of my OTHER triggers and just keep the 13 colonies stations active (I don’t want to disable ALL alerts) Is there a way to bulk edit these entries and just keep a special event station/event active?
Unfortunately that is not possible in the UI. You might want to consider creating a second HamAlert account (with a different username and email address) so you can separately enable/disable all alerts on those two accounts.
great idea! Thanks for the tip.
I wish there was a button on the main UI to toggle all triggers.
You can use the “Enable alerts” checkbox on https://hamalert.org/destinations to achieve pretty much the same effect.
A top level button would be convenient, but I can work with that! Thanks
