Audio notification not changeable
Using hamalert on Android (16) Phone, a samsung galaxy S23. In settings I enabled ‘push’ and ‘Sound’ is checked at ‘Morse’.
I tried all three options there but it constantly sounds with my phone’s standard notification sound.
I would like to hear a morse notification. At least to distinguish that hamalert has news, from all other bing bang notifications dropping in.
Is ist an issue of Android or of hamalert?
vy 73
Robert
I don’t know how HamAlert functions on iPhones, but I am having the same issue with my Samsung Galaxy A17 5G Android (16) Phone. If we could make this change and have it work as it should, it would make HamAlert so much more useful to us.
47 & 73 de Travis KB5ILY
Hi Travis,
sorry this is not real English… I am german spoken and use a translation app.
On Nov. 3rd I had a lengthy dialogue with ChatGpt. Leading to several dead ends. But it gradually became clear that the problem was not caused by hamalert.
Rather, you have to intervene at various points in Android (16) to get rid of the Hamalert sound from the standard ‘notify’
I’m not sure whether the following steps alone will achieve your goal. After all, I had already tried out various settings under the guidance of ChatGpt (and hopefully reset them all again :slight_smile:
So try this out: Open your Phones’ settings and find ‘Benachrichtigungen’
  1. Open Settings → Notifications.
  2. Go to Advanced Settings. (maybe extended settings?)
  3. Enable “Manage notification categories for each app.”
    This is not necessarily switched on by default with Samsung from One UI 6 onwards.
Then back to the top:
  1. Settings → Apps → HamAlert
  2. Open notifications.
  3. Select notification categories.
  4. Tap the existing category (not just the switch next to it).
  5. Check whether it is set to alarm instead of “silent” and which sound setting is stored there.
For me, this hasn’t yet resulted in me being able to hear a ‘Morse’ notification from Hamalert. But I added different sounds to the 8 items (categories).
This means that a Hamalert notification definitely differs significantly from the usual notifications.
I hope this helps you find the solution. And if you manage to get hamalert to alert in Morse code, please tell me how you did it.
vy 73 Robert
