Callsign trigger not alerting for CE0Y/DJ4EL
CE0Y/DJ4EL: trigger callsign category will not accept the stroke character and will not alert for either the CE0Y or DJ4EL callsign separately. How should I set up the trigger for this callsign?
Just use DJ4EL as callsign trigger.
73 de Jonny, SM5TOG
It works! Thank you for the tip! John N6ZBC
Alternatively, if you only want it to match CE0Y/DJ4EL (and not, for example, when DJ4EL operates at home or in another country), you can simply use a “Full callsign” condition.
Thank you for your very helpful suggestion. Using only the prefix “CE0” also works, because the prefix is unique to Easter Island.
