DX Gridsquare Tracking
Is it possible to set up triggers for MODE and GRID. I can find MODE but cannot locate GRID. Attempting to complete worked all USA grids with PSK31.
OK. I guess not feasible. TVM.
Would be possible to use the HamApps Callsign Database for JTAlert as the source for Grid Square? It’s updated regularly you’ll just need to download a copy and do a lookup. If the spot has a Grid Square in it, that should take precedence over the database. https://hamapps.com/
