Feature Request: Show the matching trigger rule in Telnet spots (in the Notes field)
Hi!
Thank you for HamAlert. It’s a fantastic tool!
Request
Please include the name or ID of the trigger rule that matched in the Telnet feed, ideally appended to the Notes field. I can see the matching rule in the iOS app, but in Telnet the Notes typically show things like "2 dB 32 WPM" or "FT8 -6 dB". For my workflow, it would be far more useful if the Notes also showed which trigger fired, so I can quickly understand why I received a spot and fine‑tune my rules directly from the Telnet stream.
Why this would help
  • Makes it easy to audit and tweak triggers without switching devices or contexts.
  • Helps diagnose unintended matches and reduce noise.
  • Improves transparency when multiple rules can match the same spot.
73 de Jonny, SM5TOG
