Suddenly is receive many spots of already Confirmed frequentie/mode calls.
Especially on 2m/6m.
Did not change my setup for months, but had to stop the spots to the app because every 5 minutes a received a (not needed) spot.
Aart PA3C
Aart PA3C
I see that you are primarily relying on the Club Log integration (bandslots condition). Perhaps something went wrong with the Club Log synchronization? Do the numbers of unworked band slots shown on the HamAlert triggers page look OK?
I’d suggest giving each trigger a unique comment (so you can see which trigger caused a particular alert). Also, if you post a screenshot of an alert that you think was sent to you in error, I can check what caused it.
Indeed it seems a to be a probleem at clublog or in the communication between clublog & Hamalert. Yesterday-night everything went back to normal.
I’ll attach a screenshot of alerts when the system was flooding my alarms.
All ok now
73 Aart
OK, thanks for the feedback – must have been a temporary glitch in the Club Log synchronization then.
