App on my Iphone shows number 7055! Does it shows stored notifications or is it just number of received notifications? How to empty/restore it? Iphone does not show any notifications. Have anyone had same problem? Using IOS 12.5.7.
Authentication error ?. Are you using a VPN ? Was your network connection ok.
Why IOS 12.5.7 ? Current is 17.6.1
Gordy N4LR
Hi Gordy! Thank you for reply.
I am not using VPN. Network connection OK. I have an older Iphone 6; it does not allow upgrades anymore.
Today the # on the app icon is 7726! It probably receives notifications as the number increases, but does not show them? When touching the app icon; nothing happens. It returns to normal display with icons. Strange as HamAlert worked OK roughly one month ago.
Ulf, OH2BCK
I have found an incompatibility between the current HamAlert app version, and iOS 12. An update has been submitted to the App Store (app version 1.9.2) and should appear in the next few days.
The update took care off the problem.Thank you!
This last 1 month on Iphone and PC HamAlert is not working as usual, when trying to use VPN it returns to normal, previously without VPN it was not a problem, I think it is under maintenance.
If it works with a VPN, but not without, then it might be a case of your Internet provider blocking the connection to hamalert.org, either deliberately or due to some technical problem.
