HamAlert only showing one spot even though there are multiple triggers
I have twenty triggers of which three are active on a regular basis being present dxpeditions. HamAlert has been used here for a long time without any problems.
Today I noticed that only one regular station was being spotted not the other two. I checked the settings, destinations and triggers. Nothing apparently changed there.
Perhaps the other two dx stations were having problems and were off air. That though would be a long time something around fifteen hours, since the time I have been monitoring HamAlert.
I have tried the simulate test. Athough the information was sent successfully I have not received it on the HamAlert app, on the spots screen on my Android phone. Not sure what is going on.
I have searched the raw spots received by HamAlert from the various sources (cluster, RBN, PSK reporter etc.) with the callsigns that you have created triggers for. There have only been spots for VK9CV in the past 24 hours, and for those, alerts were sent to you. The other callsigns have not received any spots.
If you see a specific spot e.g. on dxwatch.com, reversebeacon.net or pskreporter.info that you believe should have triggered an alert, then please post a screenshot of it.
Not sure about the simulate issue; please post a screenshot of the simulate page with the information filled in, and I’ll try to determine why it didn’t generate an alert.
Thank You Manuel for your message and looking into the problem.
Not sure how I send the screenshot to you from the Simulation page. Normally I send as a file. In this case a.jpg. There does not seem to be that option here. Once again a simulation was sent successfully but has not appeared on the phone app. Perhaps that may be me not filling in the information correctly.
I am out all day today and will check HamAlert later to see if other stations have appeared on my phone, In particular V55LA and S9Z. Would you let me know please, how to send the screenshot to you.
Reg
There is a button to upload an image when you post here on the forum (usually below the text input field).
Apologies. I am now receiving spots from the other triggers. One I had mistakenly erased when doing editing of other triggers. The other dxpedition had gone qrt which I was unaware of.
Unfortunately there does not an upload button that I can see…
Add Attachment: If the forum staff has attachments enabled, you will see this button on the posting page.
Perhaps this has not been enabled.
Not to worry if this is the case. The triggers are fine now, so no need to rely on using a simulation.
Many thanks for your help. A great program to use.
Reg
You can also just copy/paste an image into a post, which is what I’ve done here.
