Limit Trigger to First Spot After a Band Change
I’m pretty new to HamAlerts. I setup a trigger for 13 colonies earlier this Summer. It worked, but was disabled several times for hitting the limits. I’ve now setup a trigger for the Route 66 event. Hit the limit within the first 12-18 hours. The initial trigger was the event callsigns and mode FT8. Obviously too broad. I’ve added the 4-5 bands I prefer and spotter DXCC being USA. We’ll see how it goes.
Now the request: I really only need the spots that show a particular call sign has moved to a new band. With FT8, the specific frequency is rarely an issue. I’d gladly limit it to the first spot of that call sign on 14MHz, then have it trigger again when that station goes to 7MHz, etc. I can’t figure out if this is possible in the existing set of conditions. I searched the forum. I realize that HamAlert is really just parsing the spot data from other sources so tracking band changes is a big added load.
Thanks and 73!
Brian AK6ID
