Why does the Telnet report not convey the same information as the app?
BTW, very cool app. Thank you.
The Telnet format is designed to be parsed by common DX cluster clients, and thus needs to follow the de-facto standard format with only some basic information fields.
If you want to develop your own Telnet client, you can send the set/json command to receive the full spot details in JSON format instead.
