An import option for triggers. Ideally, an export option as well.
As a text file, CSV, or similar format. The interface should be documented so that third-party developers (like me) can write supporting tools that simplify the process of entering (and then importing) one or more triggers.
Brief background:
I’ve cobbled together some software that retrieves a PDF listing ongoing DXpeditions, parses it, and writes the call signs into a file, separated by commas. You can then copy the contents of that file and paste them into a trigger. However, this is manual work and could easily be handled via an import feature. If all the other trigger parameters (bands, modes, etc.) could also be included in the file, there would be almost no work involved. Just click “Import” and you’re done. I could modify my software so that the user’s preferred modes, bands, and other parameters are set once and then saved as defaults, so you don’t have to re-enter them for every trigger every time.
